Developers, when going to the settings, an error
I click on "customize", and it will redirect to the page https://bestorg.1b.app/admin/comment/template/, where it is impossible to configure why is this button there then?)
2) if you want to send SMS, there is no recipient of the client or his number. it needs to be automatically pulled, and not manually copied by managers
Anatoly,
everything works there, you need to press Info, then "Proceed to add a template comment" https://take.ms/beZmA
And the templates themselves are added here /admin/comment/template/add/
25.10.2022, 12:25
- here it is necessary to have the client select the process and the body field will be automatically loaded.
25.10.2022, 12:27
Susyak Igor
integrator wrote:
Anatoly,
It’s not very logical, you can replace the icon with a gear or something, or make the page like when you enter from the menu, it immediately displays add a template
26.10.2022, 22:03
Anatoly
I replaced the links with the ones you need, check
01.11.2022, 18:18
Анатолий
Интегратор
Ustimenko Igor
OneBox production wrote:
Anatoly
Yes thanks, now it's okay
01.11.2022, 21:48
