add disk space
The disk space is running out, but there is still enough space on the server. For some reason, when creating the box, they mounted 30 GB, although a 50 GB server was provided. Who can help expand the disk space to 50 GB?
Where does the assumption that there is still enough space?
On our own, we do not mount anything, we set up the provided server and install the box on it.
I suspect that no one will be able to provide you with such a service, because. on your server a 32G disk.
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 32G 0 disk
├─sda1 8:1 0 1G 0 part /boot
└─sda2 8:2 0 31G 0 part
├─cl-root 253:0 0 29G 0 lvm /
└─cl-swap 253:1 0 2G 0 lvm [SWAP]
File System Size Used Dst Used % Mounted In
/dev/mapper/cl-root 29G 29G 211M 100% /
06.10.2022, 10:58
It is possible that the Hoster from which you purchased the server service will be able to change the size of the disk.
06.10.2022, 11:01
Колесов Константин
But since 2018, the hoster has been giving me 50 GB. In my case, the OS was installing OneBox on a bare server.
06.10.2022, 11:50
Ask the hoster why the disk is not 50GB, but 32GB.
06.10.2022, 11:58
Колесов Константин
Asked. They claim that 50 is provided. But since they did not install the OS, they cannot suggest anything further. CentOS was installed to me by OneBox in 2018. I understand that further disk sizes are determined at the OS level within the available physical space?
06.10.2022, 12:20
I don't know what happened in 2018, I can tell what I see now.
Here is a screen that shows the size of the physically installed disk, what partitions it is divided into, how much of it is occupied.
And the screen where it's all distributed.
fdisk command output
fdisk -l /dev/sda
Disk /dev/sda: 34.4 GB, 34359738368 bytes, 67108864 sectors
I don't see 50GB anywhere.
06.10.2022, 12:36
Колесов Константин
Indeed, the VM was created with 32 GB of disk (not sure why). The size of the disk increased to 45 GB. Now, in theory, you need to format the extra space and mount the disk in the OS. Correctly? Can you do it?
06.10.2022, 14:15
1 hour to confirm. Please do. Send payment details by email.
06.10.2022, 14:48
Hello! Sent details to your mail
06.10.2022, 15:30
The disk space has been increased.
07.10.2022, 10:43
