Moved out the layout in the table of goods in the personal account
I forgot to add (Figure 2) these are the settings for displaying the interface.
If you display the code in the settings (Fig. 3) then the layout of the norms.
Although if you remove this item, the code will still glow.
18.08.2022, 16:25
Is the code a required field?
23.08.2022, 13:34
Da Hong Pao
Apparently so, but it is not fixed in the table, it can be removed. Therefore, there are 2 options here, either put a ban on unchecking the "code" field or remove it as mandatory. I would prefer the 2nd option :)
23.08.2022, 16:06
