It is necessary here https://univer.1b.app/admin/shop/boxclient/29/interface/blok-bek/?groupid=5 in the "List of processes" block to add the checkbox "Close block of mass change steps", which would hide the possibility massively switch to stages when selecting lists with checkboxes.
Here under this client https://univer.1b.app/app/contact/17/ (IMPORTANT! Log in using the Ukrainian interface language)
In the "My orders" menu [file]16939[/file] (Fig. 1) https://univer.1b.app/client/myorders/blok-bek/
It can be seen that you can go massively to another status.
How many hours do you need to implement?
Is it necessary that this possibility does not exist at all? Even if 1 order is switched? Then you can remove this setting for all stages, then switching will be impossible. If you still need to switch inside the order, then hide these buttons for mass switching 1h as a setting in the block.
Is it necessary that this possibility does not exist at all? Even if 1 order is switched? Then you can remove this setting [file]16953[/file] for all stages, then switching will be impossible. If you still need to switch inside the order, then hide these buttons for mass switching 1h as a setting in the block.
