BP generation action by contacts
Hello!
In the "generate BP by contact groups" action, when setting the specified day and time, processes are not generated. Or randomly generated.
What conditions must be in order for this process to run at a given time?
Original question is available on version: ru Інтегратор CRM+ERP. Компания Olmonic
Please indicate an example of setting up an action (or OneBox in which, in your opinion, there is a problem).
It is possible that the action is made in such a way that it creates a process only if the existing one is not closed. You need to look at a specific example of the action and its settings
13.07.2022, 18:53
Olmonic
Інтегратор OneBox
Processes are correctly created at the specified time and date only when the "Create processes every day" checkbox is enabled.
Probably all the same, in this action it would be possible to add "Create processes every day or at a given time and date" .
If the box is on billing, then when setting it up, this particular checkmark may raise questions.
14.07.2022, 11:56
Інтегратор CRM+ERP. Компания Olmonic Original comment available on version: ru
