Not spratsovuє to import the price of the postal worker
Zavantazhuemo in the system of price of the employee
Created Universal Product Import (xml/json) per one crown https://znaide.1b.app/app/automatization/hour/edit/ (with a note "does not work?")
I can’t find any pardons of the day in the day, or in the logs, but the goods are not announced and the calls are not updated.
Tell me, be kind, what's the problem
Good afternoon. You insert a link to Google Doc and you need to download the file when you open the link (the browser offers to download the file and choose where to download it). There is a separate application for processing files from google doc.
21.06.2022, 15:59
suggest, be kind,
Does this price list require you to connect whether it’s Google tables, chi ti, zvіdki the file itself?
23.06.2022, 18:39
If the file is public, then it doesn't matter what api key you connect for the application. The main thing is that he was working
23.06.2022, 19:42
