Evaluate the additional process Add contacts to the Contacts tab of the process
Good afternoon. https://crm.hlr.ua/
Rating needed - Add contacts to the Contacts tab of the process
In the process, add a client to the process, in the yoga card in the additional field of the contact, the name of the card is specified for the contact, which must be added to the Contact process, it is possible to add here - the checkbox Search for the original id?
It is necessary to save the process when saving the process, and it is also necessary to add an adjustment - do not save, if the contact has already been added (for example, as a helper, replace the Contact with the process on the other contact, it is necessary not to overwrite the selected value).
In addition, before the action, we will set the action Stop performing the following actions when the conditions are met
Please evaluate. Dyakuyu
12.05.2022, 13:08
