Minute cron does not work forcibly
OneBox Corp - Інтегратор
If there is an error, the products will not be loaded
Whether the action worked can be viewed in the Api application, there will be an item
11.05.2022, 01:24
Sukhanitsky Andrey
OneBox Corp.
Screenshot log
11.05.2022, 11:28
there was a space in the tag path, then I noticed and fixed it. And on a new one, the cron worked in an hour, tried to force it to turn on
11.05.2022, 11:31
the logs show that the download is working, do you need to check the settings or does it update once an hour?
11.05.2022, 16:00
Sukhanitsky Andrey
OneBox Corp.
Already earned, works forcibly
11.05.2022, 16:15
