It is necessary to take out the value of the current rate of active currencies for calculation in processes.
What variable to take for the exchange rate of the dollar, euro, ruble, zloty
It is necessary to take out the value of the current rate of active currencies for calculation in processes. What variable to take for the exchange rate of the dollar, euro, ruble, zloty
Where do you want to take it from?
In the action "Calculate and write" there are such variables
https://image.prntscr.com/image/ajXgmN4qS72U0hmfclQdCA.png
This action works with "process extra field", but is there the same with "process product extra field"?
Sukhanitsky Andrey
OneBox Corp.
so you can copy this value into the additional field of the process product and recalculate a little more complicated, but the solution
Yurchenko Roman Sergeevich wrote:
Sukhanitsky Andrey
OneBox Corp.
Legeza Vyacheslav Valerianovich iCOLOR OneBox (FOP LEGEZA VYACHESLAV VALERIANOVICH) FOP Legeza Vyacheslav Valerianovich wrote: so you can copy this value into the additional field of the process product and recalculate a little more complicated, but the solution
Andrey Sukhanitsky tell me, maybe all of them have some variables so that without lengthy manipulations, as Slava wrote?
[Andrey Sukhanitsky #42] tell me, maybe all of them have some variables so that without lengthy manipulations, as Slava wrote?
Yurchenko Roman Sergeevich wrote: This action works with "process extra field", but is there the same with "process product extra field"?
Literally, the action is called "Calculate and write the value to an additional field" and the second, which with conditions, also has such a set of variables
Sukhanitsky Andrey OneBox Corp. Integrator wrote: Literally, the action is called "Calculate and write the value to an additional field" and the second, which with conditions, also has such a set of variables
with process product fields, this is exactly what works
Sukhanitsky Andrey
OneBox Corp.
what you have already thought up, everything is elementary https://take.ms/3qhx4
all OK use variables to calculate [currency_rate_1] - Currency rate (UAH) [currency_rate_2] - Currency rate (USD) [currency_rate_3] - Currency rate (RUB) [currency_rate_4] - Currency rate (EUR) that is, we write in the additional field of the process product the value that we calculate by the formula for $[currency_rate_2]*[orderproduct_price] Exchange rate (USD)*Sale price
Sukhanitsky Andrey
OneBox Corp.
all OK
