Delete empty categories
Good afternoon. Previously, it was possible to set the automatic action once a day to "delete empty categories" Did it disappear in the OS or is it some kind of bug?
Hello, this action can be added after connecting this application
https://1b.app/ru/app/data-remove/
09.02.2022, 14:12
Zamogilny Dmitry
Thanks a lot for the tip
09.02.2022, 14:15
Olmonic
Інтегратор OneBox
If you have a tariff for data, you can install the app https://1b.app/ru/app/data-remove/
And all actions will appear.
Or you can switch to another tariff and this function will be available.
09.02.2022, 14:16
Інтегратор CRM+ERP. Компания Olmonic Original comment available on version: ru
Morozova Olesya
Olmonic - FOP MOROZOVA O.P.
I have a box. thanks for the advice
09.02.2022, 14:23
