The page is not available
Customer can't login to their OneBox
Please help me in this matter
https://viles.crm-onebox.com/dashboard/
Please contact the host.
The server responds to requests, but does not authorize.
When I try to log in via ssh it says "Connection reset by 91.200.41.204".
17.01.2022, 13:22
Tasun Sergey Vladimirovich
OneBox production wrote:
the hoster replied that everything is working, maybe the reason is something else?
17.01.2022, 16:54
Matyushko Denis
OneBox Corp.
do we look like fools?
let them ping their own server from the external network
17.01.2022, 17:35
The server ran out of space around Jan 2 22:30:11.
17.01.2022, 17:59
Ustimenko Igor
OneBox production
OneBox CTO wrote:
Matyushko Denis
OneBox Corp.
host response:
We do not conduct any work on the VPS without power from the side of the coristuvacha, including not cleanly at the place of the water initiative. At times, 39% of disk space is occupied on your server. After your call, we reloaded the server, but the site didn’t see the robot after that. Turn back, be a caress in support of Onebox.
17.01.2022, 22:00
Judging by the CRM logs, the problem appeared on September 3, 2022:
[2022-01-03 00:09:01]
point: /var/www/vilescrmoneboxc/web1/web/modules/voip/cron/cron-binotel.php
data: Array
[type] => 1
[message] => Uncaught ConnectionManager_Exception: Cannot connect to database: Connection refused in /var/www/vilesc
rmoneboxc/web1/web/packages/ConnectionManager/ConnectionManager_MySQLi.class.php:44
Stack trace:
#0 /var/www/vilescrmoneboxc/web1/web/packages/ConnectionManager/ConnectionManager_MySQLi... ConnectionManag
er_MySQLi->connect()
#1 /var/www/vilescrmoneboxc/web1/web/packages/SQLObject/SQLObject.class.php(917): ConnectionManager_MySQLi->escapeString
#2 /var/www/vilescrmoneboxc/web1/web/packages/SQLObject/SQLObject.class.php(946): SQLObject->makeWhereArray()
#3 /var/www/vilescrmoneboxc/web1/web/packages/SQLObject/SQLObject.class.php(1296): SQLObject->makeWhereString()
#4 /var/www/vilescrmoneboxc/web1/web/packages/SQLObject/SQLObject.class.php(1091): SQLObject->_makeQuery()
#5 /var/www/vilescrmoneboxc/web1/web/api/db/Xplatform.class.php(364): SQLObject->getNext()
#6 /var/www/vilescrmoneboxc/web1/web/api/services/SettingService.class.php(1183): Xplatform->getNext()
#7 /var/www/vilescrmoneboxc/web1/web/
[file] => /var/www/vilescrmoneboxc/web1/web/packages/ConnectionManager/ConnectionManager_MySQLi...
[line] => 44
Wanting to get data from the config in the console, it was a long way to get to the data base.
Return, be kind, to the retailers of the site.
Garny evening!
17.01.2022, 22:02
Here is the system log
Jan 2 22:25:01 viles systemd: Started Session 54934 of user root.
................................................. .................Jan 2 22:30:11 viles journal: Runtime journal is using 8.0M (max allowed 91.5M, trying to leave 137.2M free of 907
.0M available → current limit 91.5M).
Jan 2 22:30:11 viles kernel: Initializing cgroup subsys cpuset
Jan 2 22:30:11 viles kernel: Initializing cgroup subsys cpuacct
Jan 2 22:30:11 viles kernel: Linux version 3.10.0-1127.10.1.el7.x86_64 (mockbuild@kbuilder.bsys.centos.org) (gcc version 4.8.5 20150623 (Red Hat 4.8.5-39) (GCC) ) #1 SMP Wed Jun 3 1
04:28:03 UTC 2020
Jan 2 22:30:11 viles kernel: Command line: root=UUID=0635e2fb-4091-41e2-9a10-5efef849183a ro crashkernel=auto rhgb quiet LANG=en_US.UTF-8
Jan 2 22:30:11 viles kernel: ACPI in unprivileged domain disabled
Jan 2 22:30:11 viles kernel: e820: BIOS-provided physical RAM map:
Jan 2 22:30:11 viles kernel: Xen: [mem 0x0000000000000000-0x000000000009ffff] usable
Jan 2 22:30:11 viles kernel: Xen: [mem 0x00000000000a0000-0x00000000000fffff] reserved
Jan 2 22:30:11 viles kernel: Xen: [mem 0x0000000000100000-0x000000007fffffff] usable
Jan 2 22:30:11 viles kernel: NX (Execute Disable) protection: active
Jan 2 22:30:11 viles kernel: DMI not present or invalid.
Jan 2 22:30:11 viles kernel: e820: last_pfn=0x80000 max_arch_pfn=0x400000000
Jan 2 22:30:11 viles kernel: RAMDISK: [mem 0x02c00000-0x03c40fff]
Jan 2 22:30:11 viles kernel: NUMA turned off
Jan 2 22:30:11 viles kernel: Faking a node at [mem 0x0000000000000000-0x000000007fffffff]
Jan 2 22:30:11 viles kernel: NODE_DATA(0) allocated [mem 0x7fc06000-0x7fc2cfff]
Jan 2 22:30:11 viles kernel: Reserving 161MB of memory at 720MB for crashkernel (System RAM: 2047MB)
Jan 2 22:30:11 viles kernel: Zone ranges:
Jan 2 22:30:11 viles kernel: DMA [mem 0x00001000-0x00ffffff]
Jan 2 22:30:11 viles kernel: DMA32 [mem 0x01000000-0xffffffff]
Jan 2 22:30:11 viles kernel: Normal empty
Jan 2 22:30:11 viles kernel: Movable zone start for each node
Jan 2 22:30:11 viles kernel: Early memory node ranges
Jan 2 22:30:11 viles kernel: node 0: [mem 0x00001000-0x0009ffff]
Jan 2 22:30:11 viles kernel: node 0: [mem 0x00100000-0x7fffffff]
Jan 2 22:30:17 viles kdumpctl: kexec: failed to load kdump kernel
Jan 2 22:30:17 viles kdumpctl: Starting kdump: [FAILED]
Jan 2 22:30:17 viles systemd: Failed to start Crash recovery kernel arming.
Jan 2 22:30:17 viles systemd: Startup finished in 1.317s (kernel) + 725ms (initrd) + 5.494s (userspace) = 7.538s.
Jan 2 22:30:17 viles systemd: Unit kdump.service entered failed state.
Jan 2 22:30:17 viles systemd: kdump.service failed.
And so until today.
And yes, the hoster cleared the web server log.
17.01.2022, 23:10
