Periodically, the goods are hidden from the client's account
Sukhanitsky Andrey OneBox CORP Integrator wrote:
What is happening, how to fix it?
According to the history of changes, do the fields change for the goods?
Perhaps you are importing data from somewhere and overwriting these fields (or maybe some recalculations of fields are triggered by product automation)?
14.12.2021, 16:00
OneBox Corp - Інтегратор
according to the history of changes, the fields that are responsible for displaying in the account did not change
14.12.2021, 16:03
Can you help me figure it out?
16.12.2021, 13:08
You have to display products:
- by brands available in the LC
- no remote or hidden products
- products in stock
- filtering by additional fields displayoncabinet60=Yes and hideoncabinet71=Yes
Somewhere in this chain of sampling, you have products that do not fit the conditions
16.12.2021, 13:40
- products in stock
then all the conditions are ok, except for the availability. Prices are constantly recalculated for products. Is it necessary for the product to be in stock, can this be turned off? I don't have this checkbox
16.12.2021, 13:51
then all the conditions are ok, except for the availability. Prices are constantly recalculated for products. Is it necessary for the product to be in stock, can this be turned off? I don't have that checkbox.
there it seems, if it is not explicitly set, then it displays in stock only
If you display the filter by availability and it will be "All products" - there will be all products
16.12.2021, 14:54
understood, added a filter until the problem is visible
16.12.2021, 16:19
