You need to do an action once a day that will select all suppliers from the directory /admin/shop/supplier/
Check products for which the supplier is specified as the main supplier in the supplier tab in the product card
And from the supplier's contact card, copy the value of the system/additional fields to the product card.
That is, there should be a choice of a system / additional field from the contact card in the additional field of the product.
How long will this revision take?
You need to do an action once a day that will select all suppliers from the directory /admin/shop/supplier/ Check products for which the supplier is specified as the main supplier in the supplier tab in the product card And from the supplier's contact card, copy the value of the system/additional fields to the product card. That is, there should be a choice of a system / additional field from the contact card in the additional field of the product. How long will this revision take?
It will take about 6 hours to do this. But you should understand that it will significantly affect the performance of the daily cron - after all, there can be a lot of products, as well as suppliers - the processing will be longer.
Good day, how about 216,000 goods? Can you add a recheck to the product on the additional field? - if it is not updated, then do not update the information from the postal worker?
Valentine wrote: Good day, how about 216,000 goods?
this is an abstract question
Valentine wrote: Can you add a recheck to the product on the additional field? - if it is not updated, then do not update the information from the postal worker?
refinement of the condition for excluding products by the value of the additional field - +1 hour to the above estimate
