A couple of improvements for the personal account
https://box.criamo.com/client/
There are fields in the cart.
Address (Fig. 1) - you just need to make a dash and the conditions for mandatory selection by default, even if only one address is indicated in the contact card, you still need to select this one address.
Payments (Figure 2) - remove the item "coordinate with the manager" altogether and also put a dash and a mandatory choice. That is, if a person immediately goes to the basket, then he should not be able to immediately click "Place an order", but must choose the address and method of payment with his hands.
Also, such a moment, it is necessary that customers could fill in their details with the multilist type in their profile, and then select them in the order (by analogy with the address). If possible, please count separately.
1. 1h as customization
2. 1h as customization
3. In the user's personal profile, you can display a block with an address (for example, a universal block) so that users can edit their addresses.
04.11.2021, 16:58
Пятецкий Николай Николаевич
Insiders - OneBox
anonymous duck
OneBox production
Please issue an invoice for ESTER MT for the first 2nd revisions.
The address has already been made, it is possible to make a field in the same way, for example, a multilist, which can then be used when placing an order. For example, a client in his profile fills in the field with the following values: "LLC pipe", "LLC copper", "LLC Volvo". And then when he is in the checkout, he needs to select one of these filled values so that we can see the selected value already in the order itself.
04.11.2021, 20:23
Please issue an invoice for ESTER MT for the first 2nd revisions. preferably in the morning)
04.11.2021, 20:25
Paid, start pliz to work, so that it would be possible to set the settings on both boxes at once. Thank you.
08.11.2021, 16:30
Good afternoon. Uploaded to https://box.criamo.com/client/ and set the settings in the block "When choosing from the current addresses, put a dash as the first item" + "Remove the item "Agree with the manager" when choosing a payment method and add the field to the list of required for choice"
11.11.2021, 12:06
anonymous duck
https://box.yerocolors.com/ Can I still upload to this box? So everything works. And answer the question:
You can, similarly to the address, make a field, for example, a multilist, which can then be used when placing an order. For example, a client in his profile fills in the field with the following values: "LLC pipe", "LLC copper", "LLC Volvo". And then when he is in the checkout, he needs to select one of these filled values so that we can see the selected value already in the order itself.
12.11.2021, 16:07
1. Updated boxing
2. If you need the client himself to fill it out and then be able to choose, then now it’s impossible as far as I remember. If you can make it so that you fill it out yourself and let the client choose, then this can be done in the usual additional field.
In order for the client to fill in some field in his profile and then in the drop-down list during registration, the necessary values \u200b\u200bneed to be finalized. Will take 4 hours.
17.11.2021, 13:40
Insiders - OneBox
Okay, please issue an invoice for ESTER MT. The main thing is that in this field it would also be so that initially there is a dash in the basket and this is a mandatory field for the Choice, even if there is 1 value. To avoid the human factor. Thank you.
19.11.2021, 10:20
Pyatetsky Nikolai Nikolaevich
19.11.2021, 10:21
