Why is it not possible to install the application in your box
When trying to install the application, it says the following
An error occurred while installing the application. There are no box-mobile applications in the list available for installation
to work with the mobile application, it is enough to install the application from the playmarket or the app store and you will be able to work with your box
08.06.2023, 23:26
