The mobile application reports an invalid URL
When the address shieldtech.crm-onebox.com is entered into the mobile application, it does not come in now.
Before the transition from the old system, everything worked.
try specifying the full path including https in the application:
https://shieldtech.crm-onebox.com
31.01.2023, 20:35
Hello! Install the app https://1b.app/ua/app/box-mobile/ on your system and everything should work.
01.02.2023, 09:21
Сикорский Илья
Yeah, I installed it, it worked, but not instantly, but the next day
And yes, the protocol must be specified.
02.02.2023, 10:38
in a week or a half, a new application for OS versions will be available
we have already sent it to Apple for inspection
09.03.2023, 23:05
