I can't upload expenses to Excel in the "Documents" section. Previously, they were unloaded for a selected period, then they stopped. I found a solution to set the checkpoint "Created" and the date from here to before, everything worked, until over time it also stopped working. Now, even if you filter the list, even if you don't filter it, the entire list of expenses for the entire time the program has been running since 2017 is downloaded. Due to the fact that the list is large, it is downloaded with a link to the mail and direct download does not occur.
What is it connected with? Why did the upload fail again?
Is this due to the fact that server requirements have changed over time and web server components have become obsolete, as BOX itself says (screenshots in the attachment)?
We have a boxed version of OneBOX.
[file]16609[/file]
[file]16610[/file]
[file]16611[/file]
I can't upload expenses to Excel in the "Documents" section. Previously, they were unloaded for a selected period, then they stopped. I found a solution to set the checkpoint "Created" and the date from here to before, everything worked, until over time it also stopped working. Now, even if you filter the list, even if you don't filter it, the entire list of expenses for the entire time the program has been running since 2017 is downloaded. Due to the fact that the list is large, it is downloaded with a link to the mail and direct download does not occur. What is it connected with? Why did the upload fail again? Is this due to the fact that server requirements have changed over time and web server components have become obsolete, as BOX itself says (screenshots in the attachment)? We have a boxed version of OneBOX.
Most likely, the download code has changed or something similar. Give a link to where you are uploading and show how you did it before (when documents were uploaded at once)
