There is a problem on https://box.transmarket.ua, when outgoing calls contacts are not tied to the event, as a result, actions do not get into KPI and the Dashboard does not display correctly.
[file]8729[/file]
[file]8730[/file]
[file]8731[/file]
Good afternoon. There is a problem on https://box.transmarket.ua, when outgoing calls contacts are not tied to the event, as a result, actions do not get into KPI and the Dashboard does not display correctly.
Hello, as far as I can see, at the moment the number is tied to a contact
https://box.transmarket.ua/admin/shop/report/event/?evtype=&direction=&sourceid=&status=&showhidden=-1&datefrom=&dateto=2021-07-27+23%3A59&from=&to=0975751180&channel=&subject= &content=&durationfrom=&durationto=&line=&filtercontactid%5B%5D=&page=&mailbox=
Check if the issue is still happening
