Rate the contact box
Try installing the Automation for Contacts app
Then you can add the action "Fill in the field of the contact card based on another field" where you can copy the date of creation to the desired additional field
15.07.2021, 12:13
For the mvp version, I don’t have this field https://gyazo.com/e198b89f6895fdeed1f6ac15a41820f7 , is there more in BoxOS?
15.07.2021, 15:46
Yes, it's added to the OS.
If you need to add it to the MVP - for box users it is 1 hour of revision, and for paid cloud users it is free. Refine your Onebox URL on the MVP version
16.07.2021, 15:23
Onebox URL for whatever you need - https://ceylon.crm-onebox.com/
16.07.2021, 15:53
