Unable to add company to contact
In the contact card there is a column "Company name". If you enter the name of the company there, nothing happens, the company is not searched for and does not create. Previously, you could write the name of the company and select from the list or create. Now just create a client, then create a company, then go to the company card and enter this client in the "employees" column. This is extremely inconvenient. Can you do it like before?
Please edit:
You have php version 5.4.16 on your server, the minimum for box to work properly is 7.0. Update php on the server, if you can't do it yourself, our system administrator can do it in 1 hour of revision. It is also necessary to deliver the php-zip module
Hello. You will be invoiced shortly
21.04.2021, 16:17
Good afternoon! I have not been billed. Can you tell me when to expect the bill?
22.04.2021, 14:56
