In the contact card there is a column "Company name". If you enter the name of the company there, nothing happens, the company is not searched for and does not create. Previously, you could write the name of the company and select from the list or create. Now just create a client, then create a company, then go to the company card and enter this client in the "employees" column. This is extremely inconvenient. Can you do it like before?
[file]4586[/file]
Dmitry the oldest of the Ents wrote: Hello. No, you need to create a separate company card. The button for this can be seen on the screenshot.
No. Does not work. Just adds one more line to fill in the company. But the company cannot be chosen.
Dmitry
You have php version 5.4.16 on your server, the minimum for box to work properly is 7.0. Update php on the server, if you can't do it yourself, our system administrator can do it in 1 hour of revision. It is also necessary to deliver the php-zip module
