The client's employees fill out the contact card https://crm.ohholding.com.ua/admin/shop/users/154859/ and enter a digital value in the TIN field https://prnt.sc/woe1gx. They often make mistakes and enter incorrectly. You need a setting that will set the required number of characters to fill. If there are more or less characters, then you need to disable the ability to save in such a field and generate an error.
Is it possible to improve this, for example, add a field setting in the Universal block? How many hours?
The client's employees fill out the contact card https://crm.ohholding.com.ua/admin/shop/users/154859/ and enter a digital value in the TIN field https://prnt.sc/woe1gx. They often make mistakes and enter incorrectly. You need a setting that will set the required number of characters to fill. If there are more or less characters, then you need to disable the ability to save in such a field and generate an error. Is it possible to improve this, for example, add a field setting in the Universal block? How many hours?
