CRM - https://vuuoksa-home.crm-onebox.com
Tell me how to transfer customers to other groups in automation if the amount of the order (orders) is more than a certain amount?
Found only this option - https://prnt.sc/wl0sm6
But there are only additional fields
CRM - https://vuuoksa-home.crm-onebox.com Tell me how to transfer customers to other groups in automation if the amount of the order (orders) is more than a certain amount? Found only this option - https://prnt.sc/wl0sm6 But there are only additional fields
you can try using automation action once an hour which will place in the specified group only those contacts that meet the conditions
you can try using automation action once an hour [file]2551[/file]
