Hello, we have an inconvenience that we have to spend extra time on, it’s not at all clear why they did it and I think it’s more of a bug and not a feature - after all, your system was originally created to simplify work, but here it turns out, on the contrary, you have to click and press simply because such system logic ...
Question about filling in the "Address" field
When we enter the address, we need it to automatically become the main one, because it is the first address and it is self-evident that it is the only and main one.
This is real ?
This refinement will help all your customers not to waste extra time, because this is part of the reason why we use your system...
Hello, we have an inconvenience that we have to spend extra time on, it’s not at all clear why they did it and I think it’s more of a bug and not a feature - after all, your system was originally created to simplify work, but here it turns out, on the contrary, you have to click and press simply because such system logic ... Question about filling in the "Address" field When we enter the address, we need it to automatically become the main one, because it is the first address and it is self-evident that it is the only and main one. This is real ? This refinement will help all your customers not to waste extra time, because this is part of the reason why we use your system...
Good afternoon. This checkbox is needed only if the client has several addresses. If there is only one address, it is not necessary to check the box, this will not solve anything for the system
we have a problem due to the fact that this checkbox is missing, the action "Stop performing the following actions when conditions are met" does not work properly, in which I use the check of the value of the Country field here is a screenshot of the action, which does not work due to the lack of a checkmark, and now, for all over a thousand cards, manually put down and constantly mark new ones ... this is very inconvenient, it is necessary that the first one be set by default right away main address...
here is a screenshot of the [file]801[/file] action, which does not work due to the lack of a checkmark, and now, for all over a thousand cards, manually put down and constantly mark new ones ... this is very inconvenient, it is necessary that the first one be set by default right away main address...
