In the universal contact card block, you need to finalize the setting as in the process products block https://i.imgur.com/YmIUovB.png
That is, you need the ability to select a field (all those that can be displayed in the UB) and select fields (all those that can be displayed in the UB) to show or hide.
The fields should be displayed or hidden immediately, without saving the page, as the full name is hidden when choosing the contact type - Company.
For example, there is a field with a drop-down list, in it the value of the drop-down list is yes and no. We select - yes - we show an additional field for filling, we select - no, the field is hidden.
In the universal contact card block, you need to finalize the setting as in the process products block https://i.imgur.com/YmIUovB.png That is, you need the ability to select a field (all those that can be displayed in the UB) and select fields (all those that can be displayed in the UB) to show or hide. The fields should be displayed or hidden immediately, without saving the page, as the full name is hidden when choosing the contact type - Company. For example, there is a field with a drop-down list, in it the value of the drop-down list is yes and no. We select - yes - we show an additional field for filling, we select - no, the field is hidden.
