Evaluate the refinement for displaying a multilist in a contact card
It is necessary to make the multilist displayed as a table. Sort alphabetically, by the 1st column, set a fixed height (the maximum height of the block with values is 7 lines https://i.imgur.com/KOiBhZm.png ) + display a scroll so that you can scroll through and find the desired value https http://i.imgur.com/bfVMnpa.png
Can be done as a setting in the universal block https://i.imgur.com/Jlgivl9.png or in the field settings https://i.imgur.com/HKEc7CP.png
finalization of such a setting will take 4 hours
17.10.2020, 00:54
