Hello. When exporting contacts, the contact group is not exported ... We are looking for a solution ... Tell me, please, in the export of contacts, the value of the contact group (Groups (user.user_group)) as a separate field, you know how to add?
How exactly do you upload contacts? in export to xls this field is available - https://prnt.sc/v0clj8 , all groups are unloaded - http://joxi.ru/YmEyZdjcMqW90m
failed via "export to" at the bottom of the list box http://joxi.net/GrqbzEDtGnR6lm Now I tried your option through the button at the top of the "Export Contacts" window - it worked. Thanks a lot!
Thanks a lot!
the fields that you can display in this table are available there - https://prnt.sc/v0d86d
Poltorak Sergey
yes, but in the bottom export there is no Contact Groups field, and in the top export it is possible to unload the contact group, but there is no possibility to unload the "Activity" field. that is, at the moment, neither of the two exports can unload the fields "contact group" and "activity"
