Error when saving contact card
Here is the contact card https://invafishki.1b.app/app/contact/6075/
When we save, it gives an error, as in the first chest
We delete the values ​​from the fields that give an error
Card fields from the interface block: Legal details
We keep the card
But the error still pops up, as in the second and third chests
Checked:
- we do not have duplicate fields in the interface that could cause the existing error;
- when we try to change the data in the fields and save, it still gives an error
- looked for duplicate cards by the values ​​of the fields that give an error and did not find any
Please help to fix it
07.08.2024, 10:04
Легеза Вячеслав iCOLOR OneBox
ФОП Легеза В.В.
Maria
OneBox production wrote:
There are takes
https://invafishki.1b.app/app/contact/?code=14360570
oops
thank you sincerely
advise, please, how to clean en masse,
because it was uploaded to xls to reimport, but there is no corresponding field in the file
and also not found to mass change the value in this field by standard actions through editing contact cards
maybe there is some other working solution?
07.08.2024, 14:07
You can add the ability to clear the field in mass editing of contacts. There is an application Duplicate contacts, there you can choose to search for duplicates by code and combine such contacts
08.08.2024, 10:08
ФОП Легеза В.В.
Maria
You can clear the field in bulk editing of contacts. There is an application Publish contacts, there you can choose to search for duplicates by code and combine such contacts
The fact is that these contacts do NOT need to be combined because they are NOT duplicates.
You only need to clear the values ​​for filtered contacts in this field.
In the mass editing of contacts, it was not possible to edit this field.
Tell me, please, how it can be done?
08.08.2024, 10:14
You can add a block to mass operations to delete the INN/EGRP of a contact, it will cost 1 hour. Issue an invoice?
08.08.2024, 12:39
