Can't delete contacts Without phones
Есть необходимость работать с контактами в системе?
У нас есть готовый компонент для этого! Посмотреть компонент
there are 300-400 of them approximately in the system, I delete them by 100 pieces, base 100500 +/- and when I reach the last ones in the region of 100230 +/-, then the deleted ones reappear in the list and the number of contacts is again 100500
Good afternoon. Perhaps some of the automation actions restores them. Look at the history of changes which action restores them
06.06.2022, 14:53
something related to the outlet, since they are not restored, but new ones appear
06.06.2022, 14:57
here is an example
06.06.2022, 15:00
they are all s Posts with socket type are created. Since the same external ID
06.06.2022, 15:02
Most likely it restores them. Why are you deleting these contacts?
06.06.2022, 15:16
they don't have phone numbers, they are useless contacts for the system, just rubbish. there is not even an email
06.06.2022, 15:23
This garbage is listed in your list of chats or tasks as clients who wrote to you. If this is also useless information for you, why would you import chats from the socket?
07.06.2022, 11:11
well, to see in the system when the client writes
07.06.2022, 11:31
Well, you understand that you can't create a chat without a client, right? Accordingly, we must have a client card that created this chat for you. We can make it so that chats are imported and updated only those that have been active for the last 24 hours, so the client will not be updated and will be restored. Takes about an hour
07.06.2022, 11:36
decided to turn it off, otherwise it’s more crap than the point of importing chats
07.06.2022, 11:38
suggestion of norms, but not urgent yet
07.06.2022, 11:47
