Evaluate the completion of the block in the contact interface
It is necessary to complete the block in the contact interface "Subsidiaries" - , so that it is possible to display fields from the card of these subsidiaries (as in the block "Company employees" - )
Please rate.
The situation is that the display of blocks is different and does not allow you to easily display arbitrary fields.
Can you clarify in what form you would like to see this block?
29.03.2022, 16:06
In the "subsidiary companies" block, it is necessary to display the fields of these very subsidiary companies (specifically, the company name and address fields are of interest, but the possibility of displaying others would also not interfere), and the display in the "Employees" block
04.04.2022, 16:09
I can appreciate the finalization of the setting in the block for selecting fields for display - in this case, the display type will change by analogy with the block of company employees - it will take 3 hours.
Issue an invoice?
06.04.2022, 10:25
