OS: Glitches (bugs) in Automation for Contacts
Good afternoon!
The application is buggy: it is not displayed correctly; can't save changes after pressing the save button, a white screen appears; one action is permanently open.
https://youtu.be/A8W4ntKhsr8
Your first action is related to the Youscore application. You do not have it installed and because of this, after saving, a white screen.
You need to install the app https://1b.app/ru/app/youscore/ or remove the first action
19.11.2021, 09:35
Maria
You need to install the app https://1b.app/ru/app/youscore/ or delete the first action
Maria did as you said - the action was removed and everything else began to work correctly.
Thanks for the help!
19.11.2021, 09:54
