Good afternoon!
Employees in the application do not have contacts and there is no way to create new ones. Everything works for the leader. Tell me, what's the problem?
[file]11688[/file]
Good afternoon! Employees in the application do not have contacts and there is no way to create new ones. Everything works for the leader. Tell me, what's the problem?
In the access rights of the group of your employees, are there any settings here? Most likely, due to access rights, they have closed viewing of all contacts
In the access rights of the group of your employees, are there any settings here? [file]11689[/file]
I will add another answer to Maria, in order to create a new contact - you need to open access to the buttons indicated on the screen , click on them and a "switch" will appear to enable access
I will add another answer to Maria, in order to create a new contact - you need to open access to the buttons indicated on the screen [file]11690[/file] , click on them and a "switch" will appear to enable access
