Pass in the changed first letter with the name of the client
Take food:
At once, for the help of the changed [name_first_ru].[name_last_ru]@{|$customuser_Domen|}, an email Petr.Petrenko@kyivhlib.com is formed based on the data of the Koristuvach form.
Bazhano send an email to P.Petrenko@kyivhlib.com
It is necessary that from the "Imya" field of the Form, which was filled with Koristovach, only the first letter "Imeni" was copied into the translation.
How to implement, what is the functionality, what is the cost (varty)?
What are you shaping with? Some kind of action?
04.10.2021, 16:51
Through the "Send notifications by email" dialog for the BP procedure, vicorist change for the sheet
https://astelitgroup.crm-onebox.com/admin/shop/workflow/31/procedure/17/?status=...
04.10.2021, 17:04
Unfortunately, there are no such variables.
As an option, it is to refine smarty variables like {|$clientnamefirst|}, and then use this variable in the template together with the substr function as a modifier (cut off part of the string of the required length). This revision will take 1 hour.
Or, using the action "Calculate and write the value to the additional field if the conditions are met" and using the substr_replace function in it, replace everything after the 1st character with emptiness and write it to the additional field, and then use its variable in the letter. But this option is bad in that it will be necessary to "produce" the values of an additional field with 1 letter.
06.10.2021, 17:49
