Возникают вопросы по настройке системы? Вы всегда можете создать топик на нашем форуме и партнеры-интеграторы с радостью вам помогут!
Создать топик на форуме
Field Multilist of contacts.
No option to create a new contact in progress
In the contact card, when we are looking for a contact in a field with the "Multilist of contacts" type and it does not find it, it makes it possible to add a contact [file]10618[/file]
But when we display this field in the process, then it does not have the ability to add a contact
It just says no matches found. [file]10619[/file]
Is that how it's meant to be?
Can I make it possible to create a contact in this field in the process?
What time is it?
https://crm.sportlife.ua/
Field Multilist of contacts. No option to create a new contact in progress In the contact card, when we are looking for a contact in a field with the "Multilist of contacts" type and it does not find it, it makes it possible to add a contact But when we display this field in the process, then it does not have the ability to add a contact It just says no matches found. Is that how it's meant to be? Can I make it possible to create a contact in this field in the process? What time is it? https://crm.sportlife.ua/
Ustimenko Igor OneBox production Administrator OneBox CTO wrote: Refinement of creation from the process - 2h
We do. I'll clarify again. Make it possible to create a contact in the standard field "Connections" in the process How to set a task? We do at the expense of Sportlife hours
Ustimenko Igor
OneBox production
Administrator
We do.
How to set a task?
