Boxing https://shebo.com.ua/
The "Change contact field" [file]9758[/file] action has been added to the automatic actions when creating a contact card so that when creating a contact, the "Subscribed to the newsletter" check box is checked
A contact was created based on the letter https://shebo.com.ua/admin/shop/users/14055/, but the check mark is not present [file]9759[/file]
How can I make it so that when creating a contact, the "Subscribed to the newsletter" check box is always checked by default?
Boxing https://shebo.com.ua/ The "Change contact field" action has been added to the automatic actions when creating a contact card so that when creating a contact, the "Subscribed to the newsletter" check box is checked A contact was created based on the letter https://shebo.com.ua/admin/shop/users/14055/, but the check mark is not present How can I make it so that when creating a contact, the "Subscribed to the newsletter" check box is always checked by default?
And how exactly did you create a contact? Can I press something from writing?
Maksym Vadimovych Tyndyk
I just wrote the contact to the email with which there is integration https://shebo.com.ua/admin/shop/integrations/imap-1/control/
plus the action of creating a task based on writing https://shebo.com.ua/admin/auto/action/minute/edit/
As far as I can see - here, by default, it sets contacts that they are signed when they are created (unless, of course, the contact was previously in the database without this check mark). You can see from the history that it was updated in 0 https://shebo.com.ua/admin/shop/users/14055/history/?authorid=&systemchange=... =&filtercdateto= - were there no other actions?
You can see from the history that it was updated in 0 https://shebo.com.ua/admin/shop/users/14055/history/?authorid=&systemchange=1&filter2_key=valueold&filter2_type=search&filter2_value=&filter3_key=valuenew&filter3_type=search&filter3_value=&fieldkey=&filtercdatefrom =&filtercdateto= - were there no other actions?
no, it wasn't worth it tried to turn off the once-a-minute action to turn writing into a task, but nothing changed the contact is also created without a check mark https://shebo.com.ua/admin/shop/users/14062/
Actually, it is not created from this action - it is the parser that removes this checkmark (so that the created "spam" contacts are not sent later) Fixed the after action to work and tick. Check it out
thanks a lot works)
thanks a lot
works)
