Why are sent emails duplicated in the system?
https://prnt.sc/z3ouol
For some reason, the letters are duplicated, that is, they are sent to the addressee, and at the same time a copy will be sent to the Box system (although such a letter does not come to the mail). That is, files are also duplicated, it turns out the system is littered. Why is this happening and how can I turn it off?
Judging by the events - 2 different recipients.
Do you actually send to 2 mails (I count this as 2 events), or does the mailer forward the letter to itself.
Moreover, in the iteration you have indicated "Create events for all recipients of the letter"
14.02.2021, 09:36
What can be done to prevent this from happening? In this case, I don't really understand what I set up wrong. Tell me please
15.02.2021, 15:21
Try unchecking "Create events for all recipients of the letter".
As far as I understand, this is the problem of your mailer - when sending a letter, it supposedly sends it also to its own mail.
15.02.2021, 16:32
