When sending a letter from a process, the process #ID of the process is automatically substituted in the subject of the letter.
Can I remove the automatic number substitution?
When sending a letter from a process, the process #ID of the process is automatically substituted in the subject of the letter. Can I remove the automatic number substitution?
Sukhanitsky Andrey Integrator Integrator CRM wrote: sorry, this is the name of the process, I seem to have seen it somewhere, but I can’t find it
As far as I know, the number cannot be removed (No settings
Sukhanitsky Andrey
Integrator
apparently, that is impossible, so boxing is looking for where to attach the letter. It seems that if you put the # icon, it will not add, but this is not accurate
if we are talking about a comment block, then in the block itself in the settings there is a checkbox "Do not add a process ID to the subject of the letter"
