The filtering of the "Supplier" field has disappeared
Stop filtering and displaying supplier options.
When you enter a supplier manually, it changes the inscription to "All suppliers"
Also, the option "Sort by field" is gone (Supplier name)
(Suppliers active)
[file]4137[/file]
[file]4138[/file]
The filtering of the "Supplier" field has disappeared Stop filtering and displaying supplier options. When you enter a supplier manually, it changes the inscription to "All suppliers" Also, the option "Sort by field" is gone (Supplier name) (Suppliers active)
