The client is engaged in household appliances. It is necessary to frequently update the price list (1-2 times a day) with the output of the "availability" of the supplier's position in the table of products in the personal account for viewing by customers. This is necessary so that their client understands that the goods are not available from them, but from the supplier and it is worth ordering.
How to display the availability of a supplier - download the price of the supplier indicating the value of the field - https://partstore.crm-onebox.com/admin/shop/products/1050/supplier/ - https://prnt.sc/xxl044 (availability in pcs. and checkbox "presence").
Information with a checkmark for availability should be visible in the personal account at the time of searching for a product and displaying it in the product table here - https://prnt.sc/y58s94 , https://prnt.sc/y58ti6 .
What solution I see: Refine in the product search block in the personal account the output of
The client is engaged in household appliances. It is necessary to frequently update the price list (1-2 times a day) with the output of the "availability" of the supplier's position in the table of products in the personal account for viewing by customers. This is necessary so that their client understands that the goods are not available from them, but from the supplier and it is worth ordering. How to display the availability of a supplier - download the price of the supplier indicating the value of the field - https://partstore.crm-onebox.com/admin/shop/products/1050/supplier/ - https://prnt.sc/xxl044 (availability in pcs. and checkbox "presence"). Information with a checkmark for availability should be visible in the personal account at the time of searching for a product and displaying it in the product table here - https://prnt.sc/y58s94 , https://prnt.sc/y58ti6 . What solution I see: Refine in the product search block in the personal account the output of
The 2nd moment is that when the prices were loaded 1 time and the availability checkbox was checked and brought to the personal account. Before the next download of the price list, you need to remove this availability checkbox from the Suppliers in bulk for all goods in the system. Why: if last time you downloaded 1000 products, this time 900 from the same supplier. Then 100 products will remain with the old availability value and customers will order them in the personal account. This must be excluded.
Timofeev Artem Olegovich Employee wrote: What solution I see: Refine in the product search block in the personal account the output of the value "availability at the supplier" and the same in the product block.
do you mean popup?
do you mean popup?
Ustimenko Igor OneBox CTO wrote: do you mean popup?
Well, a popup, in this case, is the output of the Product Search block. If we are talking about the same thing, then yes in it. And also in the LC products table
Ustimenko Igor
OneBox CTO wrote:
do you mean popup?
give screenshots what to add
Employee wrote:
Ustimenko Igor
OneBox CTO wrote:
do you mean popup?
Ustimenko Igor
Employee wrote:
Ustimenko Igor
OneBox CTO wrote:
do you mean popup?
https://partstore.crm-onebox.com/admin/shop/boxclient/15/interface/
https://prnt.sc/ypfo9g
This is what should be displayed in this table. You need a field where it will be displayed. Just the amount of availability, which was loaded with a price list. If there are several suppliers, we simply display the amount in the field Is that possible or what is the best way?
Ustimenko Igor
OneBox CTO wrote:
and what to add give a screen
Employee wrote:
https://partstore.crm-onebox.com/admin/shop/products/1050/supplier/ - https://prnt.sc/xxl044 (availability in pcs. and tick "availability").
if there are more than 1 suppliers, then for each we show if 1 then just data 3h
Employee wrote:
Ustimenko Igor
if 1 then just data
3h
Clarification whether instead of a separate column it is possible to display in the column with a warehouse like this - https://prnt.sc/yqjjp3 , write the amount of availability for all suppliers. Give the name of the line "Availability at the supplier"?
Timofeev Artem Olegovich Employee wrote: The 2nd moment is that when the prices were loaded 1 time and the availability checkbox was checked and brought to the personal account. Before the next download of the price list, you need to remove this availability checkbox from the Suppliers in bulk for all goods in the system. Why: if last time you downloaded 1000 products, this time 900 from the same supplier. Then 100 products will remain with the old availability value and customers will order them in the personal account. This must be excluded.
Need answers for this moment
Ustimenko Igor
Employee wrote:
Ustimenko Igor
if 1 then just data
3h
Timofeev Artem Olegovich Employee wrote: Clarification whether instead of a separate column it is possible to display in the column with a warehouse like this - https://prnt.sc/yqjjp3 , write the amount of availability for all suppliers. Give the name of the line "Availability at the supplier"?
No
Timofeev Artem Olegovich Employee wrote: Need answers for this moment
and now how do you think?
No
Ustimenko Igor OneBox CTO wrote: and now how do you think?
I do not remember that it was possible to massively remove the presence of all suppliers. Please specify if there is such an option.
Ustimenko Igor
Timofeev Artem Olegovich Employee wrote: I do not remember that it was possible to massively remove the presence of all suppliers. Please specify if there is such an option.
