1. Toysi throws an access error under your details
here is the request that is sent
http://toysi.com.ua/xAPI/index.php?mod=GTOVA&type=json&cid=ХХХХХХХХХХХХХwhere XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX 30 300 300 300 300 300 300 300 400 400 400 400 400 000 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 have md5(YourLogin."_".base64_encode(Your password))
API response {"error":"Dostup zapreschen - kluch dostupa 'key' otsutstvuet v zaproshennoy ssilke or nepravilnyy. Svoy kluch dostupa vy mojete nayti v lichnom kabinete toysi, v razdele 'API'."}
if they have changed api - then let them give new documentation, I will appreciate it
2.AFK
they either changed their download or you inserted a link to the wrong file format that is integrated
since the action takes goods from the data->row tags and according to your link there are items->item + other names of all fields
