Problem with xml price list import
In the hourly action "Universal import of products (xml / json) (Price PLU)" https://knz.market/admin/auto/action/hour/edit/ there is some problem with loading or processing the file.
The system finds the file by clicking the "Check file existence" button, and when trying to import, it throws the error "xml / json file ... not available or empty" https://i.imgur.com/WD2e6np.png
There are two suspicions, but I would like to know exactly what the reason is.
1. The link is not to a specific xml, but to a folder. When a link is inserted into the browser, an xml file is downloaded (does not open) with a name different from the name of the folder. But I doubt this version, because. we have another action that pulls an xml file from google drive in exactly the same way and it rarely throws such an error.
2. In the xml itself, almost every product has an empty self-closing <statuses/> tag. But, as far as I know, such tags are valid in xml and
You did not specify in which of the 7 actions, it does not download for you.
Guess it's (Price PLU)
When you insert a link into the browser, it is downloaded only because you are authorized on this site,
if I do it, then I am simply redirected to the authorization page.
30.01.2021, 01:43
Thank you, I didn't think to check this one.
01.02.2021, 09:59
