Good afternoon. I'm trying to download a price list from google doc and when "Confirming the correct recognition of the price list" there is no price [file]10984[/file] after updating the product also has a zero price.
https://cabinet.tehnolavka.com.ua/admin/shop/products/supplier/import/history/ operation id 12695.
Here is the supplier https://cabinet.tehnolavka.com.ua/admin/shop/supplier/24/ , the link to the price is in the "Supplier Information" field
There are several options, but here are a couple of the main ones: 1) The column with the price is chosen incorrectly 2) Before the column with the price there are empty columns, in this case they are shifted
Good afternoon, Maria. Prices have already appeared, but not on all products [file]11102[/file] https://cabinet.tehnolavka.com.ua/admin/shop/products/914242/supplier/
Most likely in this product there are separators / line breaks that transfer the price not to the 3rd column, but somewhere further on this and the information on this product was not pulled up
No, I checked. Everything is the same as in other products. You can see for yourself, Here is the supplier himself https://cabinet.tehnolavka.com.ua/admin/shop/supplier/24/, the link to the price list is in the "Supplier Information" field. Here is the link to the product
Sukhanitsky Andrey OneBox Corp. Integrator CRM wrote: Can you give access to your system? I will try to figure out if there is a software error in this problem, or if you can still solve it yourself.
Good afternoon. Please give me mail
Sukhanitsky Andrey
OneBox Corp.
