How to bypass the error when changing the status to Kasta "Unable to transfer the cost of delivery when My tariff or Kasta tariff is selected"
Action "Change order status on Kasta.ua" https://1b.app/ua/forum/integrations-with-price-platforms-and-marketplaces/16689... zakaza-na-kastaua/
Gives error "{"code":"delivery-cost-mismatch","message":"Could not transfer delivery cost when My rate or Kasta rate is selected"}"
How can this problem be solved?
Hello, I suggest you read the answer to your similar question here.
https://1b.app/ru/forum/integrations-with-price-platforms-and-marketplaces/16689...
20.03.2023, 17:36
Юля
менеджер
Zamohilny Dmytro
We got acquainted, but did not find a solution
Within the framework of this task, I would like to receive some solution, how to bypass this problem (error)
As part of that task, I wanted to globally understand how the action works and what should be selected in the settings (I was interested in the delivery service, etc.)
Therefore, if you can, give an answer there according to the action, and here it is possible to bypass the problem, if you want, then let's correspond in one task
20.03.2023, 18:23
