Previously asked a question, but did not receive an answer https://crm-onebox.com/ru/support/integration-with-onebox/6394-otsenit-dorabotku-facebookmessenger/
Please rate
Good afternoon. Please read the topic https://crm-onebox.com/en/support/integration-with-onebox/1023-rasshirit-kolichestvo-podklyucheniy-k-prilozheniyu/ where they minimally made it possible to receive pushes from several fb
This is a so-so solution, I need to connect 2 different applications, they will have both different tokens, and not just 1 as they did Here's a duplicate of how you can define a page: Push has this parameter
This is just the page id on FB And connects to 1 token - 1 page Need to improve: 1) the ability to add several identical settings, such as with promo 2) add to the integration settings the ability to specify the Facebook ID of the page on which the definition will be 3) In action, finalize the choice of integration Or, as Max wrote, make the settings in action, and in the integration itself write "Specify all data in action"
Push has this parameter [file]7376[/file]
[file]7377[/file]
This is just the page id on FB [file]7378[/file]
Need to improve:
Sukhanitsky Andrey Integrator Premium partner Integrator CRM wrote: Or, as Max wrote, make the settings in action, and in the integration itself write "Specify all data in action"
I think this option will take less time
Sukhanitsky Andrey
Integrator
Premium partner
. clack clack wrote: once again: now you can specify 2, 3, 8, 19 tokens and receive messages on them. What don't you want?
picks up their division into different processes, they can be separated by page id, let's finish them in action
Good afternoon, the setting "Run the action only if the message came from the page with the id" has been added to both Facebook messenger actions. Tell me, which boxes you need to upload so that you try out the setting?
Processes arrive correctly
Only here https://crm-onebox.com/ru/support/integration-with-onebox/1023-rasshirit-kolichestvo-podklyucheniy-k-prilozheniyu/ did not take into account 1 important point - when sending a message from the "Comment Feed" block box does not understand from which token to send a message.
