Integration of monobank FOP account
The integration with the physical monobank has been set up and has been working well for a long time, but it’s impossible to connect the sole proprietorship - the API pulls the account - everything is set up, but payments for the sole proprietorship do not go into the statement / wallet itself but they go to the individual. what is the problem is unclear. mono payments are visible in the application
OneBox Corp - Інтегратор
Check the access rights of the contact CRM OPTIUM bot, it must have administrator rights in order for payments to be created
13.07.2021, 22:42
yes it worked thanks. But the fact that nothing is displayed in the purpose of the payment except for the name is this a problem on the mono side or is it something to set up again?
14.07.2021, 14:16
Zubarev Sergey
option 3:
1) only the name is indicated in the assignment
2) mono does not give other data
3) we take data from another field
14.07.2021, 15:33
Sukhanitsky Andrey
integrator wrote:
Zubarev Sergey
option 3:
1 made a test payment specially written in the appointment - and in the application and us the appointment is in the vanbox is not
2 mono support swears that all fields are given and even threw off an example and in the examples everything is there
3 most likely you take only from the field "payer" and the field for the purpose of payment is not taken into the CRM at all
20.07.2021, 13:46
Zubarev Sergey
Most likely, this is the case, put a Ticket with an example, the developers will be able to say more precisely, I do not have such access
20.07.2021, 15:18
