Good day Victoria.
1. You can get an API token from Monobank and enter Yogo into integration here
https://shopforcars.crm-onebox.com/admin/shop/integrations/monobank-integration/...2. Automatically every once in a while, a Monobank Statement is available. in this case, select the account ID *: the card number, how you want to connect and select "Koristuvach in which payments will be made *:" and "Account for which payments will be insured *:" so
https://prnt.sc/w7sxrk3. If you still don't have an open account for card monobank, add it here
https://shopforcars.crm-onebox.com/admin/shop/finance/account/everything is ok - then if the payment arrives on the Monobank card, you will have to deal with finances here
https://shopforcars.crm-onebox.com/admin/shop/finance/ (you can sort it out according to your card)
It is necessary to automatically screw up the joe of the zamovlennia - here you may not see it, because in the confession, as a rule, there is no data according to the payer / number of the zamovlennya. also fasten the payments to the registration number like this
https://prnt.sc/w7t166write everything away
