Do not practice doopration.
Robili doopratsyuvannya #2015618600
https://orc-test.kiev.ua/admin/shop/finance/account/24/control/
Checkmark to stand by the gaman
Ale 20.11 payments were made without category: 10078, 10081, 10088, 10075
How did it happen?
I duplicate, so I didn’t take it off
https://crm-onebox.com/ru/support/finances/3865-problemi-z-doopratsyuvannyam-gam...
Valentin, what was the procedure for making payments, automatic transfers, transfers at the stage?
03.12.2020, 11:23
Good day
Can you please tell me what the problem is?
03.12.2020, 14:25
Requiring intelligence, as if I myself made payments -
via https://orc-test.kiev.ua/admin/shop/finance/payment/add/
either through a block at the process, or in another area.
Be kind, describe
03.12.2020, 15:57
03.12.2020, 16:11
Why does the problem appear on all payments without a category, is it possible to conduct test payments on your box?
03.12.2020, 16:27
Zamogilny Dmitry
You can do tests.
No, it didn't work once. We knew about it vipadkovo. It is not possible to make a payment at once without a category
03.12.2020, 17:41
The problem was that for payments between gamantsy, it didn’t work, because it was switched on by the gamantsy-otrimuvacha, which I corrected.
04.12.2020, 15:44
