You need a setting that would go to the stage in the add. the payment field would write some value, now we can either fill it in when making a payment or later manually.
How much will it take to finalize the action of this format?
You need a setting that would go to the stage in the add. the payment field would write some value, now we can either fill it in when making a payment or later manually. How much will it take to finalize the action of this format?
you can make a separate action that fills in the additional payment fields of the current process, in which this field has not yet been filled. You will bet on a procedure or somewhere else. Takes 4 hours
