payments stopped being imported PrivatBank MVP version
Good afternoon, payments from PrivatBank MVP version of onebox have stopped being imported, what is the reason?
Privat24 Autoclient Account statement does not load payments from the beginning of the day yesterday, the last payment came in at 17:49. Maybe due to a change in API data? https://prnt.sc/AqoS0jqKOhBQ
Most likely, the private server updated something - all services update.
The MVP version of the system has not been officially supported for more than 3 years - for the correct further functioning of your system, you need to update the version to OneBox OS
07.08.2025, 12:29
At the moment, the update is not suitable, something needs to be decided with this, maybe change the data via Api or something else!
07.08.2025, 12:31
Your version of the system is not officially supported and in the future, there will only be more cases where integration with external services does not work.
07.08.2025, 13:21
maybe the situation is more global: https://1b.app/ua/forum/integrations-with-banks-and-payment-systems/19683-proble...
there is a similar case on OS
07.08.2025, 16:21
