Privat24 for Business Integration (Autoclient)Access is restricted from April 1, 2025
From April 1, 2025, access to the "Integration (Autoclient)" menu will be restricted for non-notarized persons in the "Privat24 for Business" online bank.
If you need access to this service, please contact your company manager to expand it.
To provide access, you must:
pict1
use the “Settings – Access to services” menu;
pict4
open the required trusted person and click the "Edit" button;
pict4
check the box next to the "Integration (Autoclient)" service;
pict4
save changes by signing with SmartID or UEP (file key).
There is a letter from Privat, I wonder if this concerns the integration of the Privat24 application with Box? If so, what should I do? Will Box and Privat agree on this?
If you have any payments being pulled from Privat24 by the autoclient, you need to take the actions indicated in the letter, otherwise the payments will stop being imported on the 1st.
20.03.2025, 15:34
